Any powerful car is a problem when you boot in mid corner. Guess this is why you term the 1.4K is okay, its not powerful enough such that the the tyres have no problem with lateral grip and maximum traction force at the same time.
Just re read your first post. Mappable ECUs are good modifications to any engine, has nothing to do with them being turbo'd or not, turbos simply operate at a higher manifold pressure when you press the loud pedal. On all engines you simply optimise the fuel and ignition at many loads sites, (around 200 sites) based on throttle position and engine rpm (on speed density you use MAP and engine rpm and hence is why its favoured to turbos cars simply because MAP is a better indicator of what fuel the engine require)
Throttle bodies will total change the demands on the engine and how well the cylinders fill and certain resonant frequency effects. You'd really need the dyno to tune ignition correctly for the minimum timing for the best torque and it would certainly require longer than 1 hour of work.
Im of the opinion that you not really asking in the right place either, a motors spin off section of a computer forum is unlikely to found as much info as other sites out there.
