just constant verbal abuse, as for doing stuff wrong in his eyes the army is wasting my life infact thinking of it, anything i do or say he dosent agree with. i try to stay out of the way most of the time but the main reason hes annoyed now is because i dont have a job and im wating for a few things to process for the army.
Ok, time to grow up - I mean that in a positive and constructive way.
It sounds like your parents are worried sick that you may end up hurt or killed. It shows they love you and they’re concerned. Put yourself in their shoes with your son wanting to enter a profession that has a real chance of you dying. It sounds like those are raw emotions coming from your dad.
If you want to join the army then do so. Vow to make yourself a success.
Ask your parents to sit down at the kitchen table with you. It’s probably completely unexpected - switch off all distractions (TV, Music etc).
Apologise for flying off the handle.
Then in a comfortable, low, unwavering voice tell them that you understand that they are worried sick about you joining the army. If they interrupt, talk over your, raise the pitch or volume then continue at the same volume, pitch.
Tell them that you understand that they would like you to lead but the life you want to lead is going to be different. Tell them that you love them, and you know that the idea of the army is worrying them sick but you want their support with the life you wish to lead.
Listen. Listen and Listen. Keep calm, focused and maintain a confident low steady sounding voice that slower than you’d normally talk with them.
If they fly off the handle with comments such as “well if that’s the life you wish to lead..” etc then just let it slide, remain calm and continue in the same low confident voice. Don’t escalate but reiterate that you will be joining the army and in the mean time you will be looking for a job to pay your way.
Don’t forget - for them it’s going to be the first time they’re probably seeing the kids out the house and it tends to be emotional. By keeping calm, and in a low steady voice you’ll appear confident and by listening.
When you’re hunting for the job - discuss the progress (applications etc) with them. It shows you’re doing something. When you’ve got your pay - give some if it for upkeep.
Just thoughts - sorry if they sound a little patronising.
