Thrustmaster AVA Joystick base
29 Oct 2002
Abingdon, Oxfordshire
Has anyone picked up one of the new Thrustmaster AVA bases, it seems to be a upgrade over the Warthog Hotas etc.
I'm looking for a flightsim stick with a bit more quality than the plastic Thrustmaster TCA and wondered if people had experience etc
I've not read anything bad about the AVA, but it has arrived at a rather difficult time for TM.
We already have high quality metal bases from VKB, Virpil and WinWing. I get the impression that there's probably not a huge amount in it, so if it's going to be from them, maybe focus on the grip options.
Additionally, the first vaguely sensibly priced force feedback base has started to arrive from Moza, with more manufacturers expecting to launch soon.
Not heard of the Moza so I'll def check that out as that sounds interesting depending on price and if not sounds like there is plenty of choice otherwise. I would mainly be interested in Airliners and GA flying.
For GA, also have a scan at the new Virpil Yoke and the Honeycomb kit.
The Honeycomb stuff seems to be well thought of.
Thanks, I already have the Honeycomb Alpha Yoke for Airliners etc but fancied something else for other aircraft etc, there appears to be a few options I need to do some research on.
I would go for Virpil WarBRD base, I have mine for years its so smooth and very good quality. https://virpil-controls.co.uk/vpc-warbrd-d-base.html
Thanks, I'll def put this on my list to look at, looks ideal for my needs a bit cheaper than the AVA.
Then is a 100% buy over AVA Virpil are king.
Seems like the Virpil is better engineered, I see it has dual cams on each axis whereas the AVA is just single cam? Watched a few reviews and I think this is def the one for me.
I'm surprised it was cheaper than the AVA to be honest, another option is winwing you can get a base and F-16 grip for little bit more. I have only used their throttles before but I ended up sticking with my Virpil throttle.
yeah a couple of my squadron mates have the Moza and say its really nice, especially for the warbirds and phantom. gonna be swapping my Warbrd base for one in a couple of months
