well it really depends, do you have a before and after cable management photo of your pc?
Unfortunately not... didn't think of that. But I have a side fan for intake, and a rear fan for exhaust, with a Freezer Pro 7 pretty much perfectly aligned between them. Before I had a large bundle of cables right in front of the side fan (the big mobo one, plus all the HDD and Optical Drive cables, including an IDE ribbon), and I had one lone cable between the Pro 7 and the rear exhaust, which I imagine would just really stir up a smooth flow rather than block it. But now, I don't!![]()
, then the cables would be blocking airflow and cool air would have a hard time travelling through your case, let alone exhauting it.
Good god.. buy a heater. You'll get sick if you stay in that temp for long periods of time =/
Oh well!
