Tight vnc alternative for OSX
15 Feb 2003
Europe
It seems that their isn't an OSX version of Tight VNC.
Whats the next best alternative that will connecting to my Ubuntu machine as if I was sitting in front of it?
I often use FreeNX, but that's not the same as being sat in front of the machine as it opens a separate desktop session.
vnc is built into os... its called screen sharing.
The easiest way of accessing it is just type vnc://<ip address or machine name> in the address bar of safari.
Doing that I'm told that the computer I'm trying to connect to doesn't support encryption. I want to send data via SSH so it's encrypted.
if you load the app itself
/System/Library/CoreServices/Screen Sharing.app
There's an encryption option in preferences.. not sure how it works as I've normally don't use screen sharing but Apple remote desktop which is more of a network manager version but its not free. Both have encryption options... but I've never used neither.
isn't the windows' version of tightvnc a java app? I take it it won't run with mac java?
edit: is this any good?
http://www.mactech.com/articles/mactech/Vol.20/20.07/VNCOverSSH/index.html
as far as I'm aware/been told... vnc over ssh is a bit of overkill unless the server machine is being remote'd on to via internet.
