- 9 Mar 2005
- Wakefield
I currently have a shuttle so will be need a case and some power to go with this. I have storage space but looking to get a new 1TB drive for the operating system, I wondered about SSD but my PC is on 24/7 and not sure how that affects life span etc (need about 4-500GB if anyone suggests one). PC not really used for games and I have a graphics card I can still use. I do a fair amount of encoding etc so need the CPU power.
So far I have come up with:
Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit
Super Flower Golden Green HX 550W "80 Plus Gold" Power Supply
WD Black 1TB 7200rpm SATA 6Gb/s 64MB
Lian-Li PC-9FB Aluminium Midi Tower Case - Black
Sapphire Vapour-X w/ Dual Fan 120mm CPU Cooler
Case isn't really a must, just something I have in the basket at the moment. There's so many choices and if someone can suggest a cheaper MIDI tower then I will consider it.
Haven't added a motherboard as I'm a bit out of touch at the moment. What's the difference between the 3 1151 chipsets on the boards? I'm not going to be overclocking to the limits, might have a small5-10% tweak but any old board can usual handle that.
Budget is about £800, would like to keep below that but if there is massive gains to be made by going a smidge over then I will consider that too.
All help is appreciated.
