Is camera going to be somehow protected or exposed to outside air?I want to take a time lapse of my pond...
You will need to provide more details of budget and use case., ut as above a good Nikon DSLR can do this just fine.
Better have proper weather sealing in later case.
Also time lapse features of cameras usually have max frame number limit so likely going to need some restarting of time lapse program.
(there are remotes which can do interval)
Also depending on interval time there's going to be really lot or insanely lots of shots so electronic shutter would avoid wear risk of mechanical shutter.
Here in Finland one group of amateur astronomers used to do lots of interval/time lapse shooting.
They did it with Olympus compact cameras controlled by PC software.
https://www.youtube.com/channel/UCM6Azxt6v0l37IzI7iZqy6Q
While protected from normal rain it would be still exposed to all temperature changes along with humidity.It's going to be in open air under the summerhouse roof so will not get wet from rain
Also rain doesn't always come vertically...
(sometimes it's more like horizontally)
So weather sealing would definitely be in good to have list.
Olympus doesn't have much compacts anymore, though not that any maker has much of them.
And not sure how good time lapse function compacts they have.
Though Olympus seems to be one of those who include most of software based features throughout line up.
I just checked and in E-M1 MkII highest number of taken shots for one run is 999.
Both waiting time from shutter press to first frame and interval between frames can be set up to 24h
Also AC adapter would be pretty much needed to avoid frequent battery swaps.
While cameras are able to go to sleep mode between shots it would be simply better to have AC power for minimizing amount of manual work.
Actually not that many cameras might have AC adapter as accessory.
Some makers seems to be really liberal about use of term "weather resistant" when there's clear holes in sealing...
https://www.lensrentals.com/blog/20...ur-camera-wet-teardown-of-a-salty-sony-a7sii/
Question is really about finding out which cameras have DC input...I have power so I will run it from mains...
You put them in water tight sealed boxes.Do I need a DSLR outside? Won't it get damaged ?
Have you considered a wildlife camera trap? Designed to run on DC or batteries and obviously live outdoors
https://shop.naturespy.org/camera-trap-selection/ is where I got my trap from. They were very helpful with some post-sales questions as well.
Do any do timelapse ? Don't they just record video or take a photo when the sensor is triggered ?
