Time Spy Extreme DX 12 Bench.
You’ll hit the top eventually, you’ll probably need a really really expensive ram kit to get those extra 600 points or, wait for
more driver updates.
I do wonder if DDR5 will make a big difference.
Yep, hopefully more driver improvements will come and maybe we can get a clean sweep of the 3D mark threads bar Port Royal.
Do you really have a 3090 paired with an 11400 cpu? Is that just temporary?
Well there’s something you don’t see everyday.
Yes, I do have my 3090 FE paired with an 11400. The 3090 won't fit in my main PC. As for permanence, pretty much until the next generation of CPUs arrives. The 11400 is pretty much the same as the 8700 in my main PC and I play at 4k so most games are GPU-limited, and most of the games I play don't use more than 6 cores anyway. I've simply no need for a better CPU for games. And with the 3090 - even though bought at RRP - and an iPad Pro and the 11400 box I've had a significant tech spend already this year.
26th in the world. No LN2/Chiller, no water cooling, no hardware mods. :D
5950X @ 4.825Ghz
6900 XT Toxic @ 2860Mhz/2162Mhz
21.7.2
AMD Radeon RX 6900 XT video card benchmark result - AMD Ryzen 9 5950X,ASUSTeK COMPUTER INC. ROG CROSSHAIR VIII HERO (3dmark.com)
SCORE 12 185 with AMD Radeon RX 6900 XT(1x) and AMD Ryzen 9 5950X
Graphics Score
12 309
CPU Score
11 532
