Its ok dude the first one is the hardest. Once you have one under ur belt its pretty straight forward.
Thank you much appreciated.
Another thing that i found worked better than tilting the case around is to remove the rad from the case and move the rad around while the case is sat as it would be used (eg upright) this way the pump doesnt run out of coolent as easy and the rad can be the lowest part with air shooting to the res.
Hope that helps good build loving the progress video
You get the fun task of doing all this in reverse when you drain the system too haha.
The number of times Ive thought the systems all drained and sorted but then picked up the rad and got another load of coolant pouring out on me haha.
Haha, whats this one going to be then? Finally got it all working and stuff... or has there been a massive disaster?!
Just looked at your latest vid, how much did you clean your rad out before you set everything up? There is one shot of the res in your vid when you can see tiny bits whoosing in the res, these are probably bubbles. Its hard to tell but these could also be very fine "silt" which is usually from solder flux which hasn't been fully flushed. This stuff can easily be mistaken for tiny bubbles. You can tell for sure when you switch the power off, if it is solid residue it will sort of float about when the water stops moving, whereas bubbles would tend to rise. Also, looking at your loop config again, you best method to bleed would be to put the base on its back, i.e. the side where the mouse/kb/psu power leads all plug in, that wants to be on the bottom, making sure the res has enough water to ensure the pump inside is totally submerged. If you position the case like this whilst filling the rad inlet/outlet are in the right orientation. You mention a couple of times above about the pump stopping cos its ran out of water, you really shouldn't be doing that as it is not good for a pump to run it dry. When you tilt and move the case it is critical you turn the power off if it looks like the fluid level is going to go below the pump inlet, i.e. the classic flip on/off maneuver.
Tubing looks tidier mate. Once you stick some more feser in there the air will sort itself out. I expect your temps will get even better once theres no air in there and with the voltage your running 4.5Ghz looks possible.
I actually like the fact your doing vids. Not very common thing to do but helpful for us helpin you and for helping others. Very good of ya mate!
well if anyone has any pics of their watercooling set up to give me an idea of what is needed to get this up and running that would be much appreciated
i love this set up mate glad i found yours you wanna spec my pc for a water rig lol.
