Tiny bit of unallocated space (hardly worth mentioning)
8 Nov 2002
Kent
Could I merge this safely back into an existing partition?
you get that quite often, it's just formatting data, i'd ignore it..
some formatting tools create it, some don't
It's reserved system space for when (if) you convert from a basic to a dynamic disk. If you never intend to convert your disks from basic to dynamic then you can try use DISKPART or similar to merge it into the next closest partition.
Thanks I think Ill leave it. According to Microsoft you lose partions if u convert back to a basic disk and therefore need to backup all data; but this is the operating system disk so can't mess about with it without a reinstall.
Apparently dynamic disks support extending the volume to include unallocated space.
"Windows XP Professional supports two types of disk storage: basic and dynamic. Basic disk storage uses partition-oriented disks. A basic disk contains basic volumes (primary partitions, extended partitions, and logical drives).
Dynamic disk storage uses volume-oriented disks, and includes features that basic disks do not, such as the ability to create volumes that span multiple disks (spanned and striped volumes)."
http://support.microsoft.com/kb/309044
http://www.helpwithwindows.com/WindowsXP/howto-20.html
