- 8 Feb 2008
- UK
Hey guys
I've had a 500gb Seagate [one of those that came with dodgy firmware] as my boot drive for about 2 years now. Lately boot times have increased and its been acting up a bit. Extra long open times on certain files, particularly unzipping files and then opening them - this might be something else but I get a feeling its the drive. Since I'm not sure about the drive and I'm pushing its limits in terms of space, I'm thinking about getting a 1Tb to replace it [probably the F3].
This is where I face a slight issue, since I am away at university and was foolish enough to leave my windows disc at home, I figured I would have to clone the drive - I assume its also quicker than a fresh install so I can get back to work. This is something I haven't done before so I have a few queries I hope you guys can clear up.
Firstly i'm assuming the drive sizes aren't an issue?
Will it simply be a case of plugging in the new drive initialising it and formatting it as if it were a second drive, then cloning it through the OS and then setting it to the boot drive in the BIOS? Will there be any other steps or issues with it being a different drive - drive letters associations, drivers ???
How long will this process of cloning take on a 500gig drive with nearly as much data - i.e. is it an overnight job?
Will the new drive bear the file same structure as the one it was cloned from? Does this mean it will be fragmented. I guess not really an issue after a defrag?
Will I need to re-activate windows - it's going into the same desktop, the only change is the drive?
Thanks in advance for any help or advice
Regards
MA
Regards
MA
