Titan Wave and cooling
10 Jan 2011
I bought the Titan Wave pre built using the Phanteks Enthoo matx case a few weeks ago and i mainly use it for gaming, playing Fallout 4 and GTA 5 at the moment. I noticed while gaming the aio cooler fans get really lound and found the cpu is 56°C +. I took the top of the case off and with the game still running the temp went down to 36°C. The fans are mounted ontop of the radiator and pull air in so the top of the case must be really restricting the amount of air the fans have access to.
I found this post when i was researching, before i bought this pc and this picture shows the fans mounted under the radiator pushing hot air out rather then trying to pull cool air in like mine is and im wondering how difficult it would be to change mine to do this? I have difficultes using my right hand because of a brain tumour which is why i opted for a pre built so im abit limited to what i can do.
Firstly your temps are absolutely fine. Is there somewhere you can adjust the fan curve such that it's quieter at those temperatures. Changing the fan orientation might not help.
It's possible they are mounted to the top of the rad but are pulling hot air out.
As for your actual question. It could be quite difficult as you'll need the screws to mount the radiator to the case and screws of the right length for mounting the fans to the rad without the case. Some radiators have unprotected channels underneath the screw holes and if you use a screw that is too long then it'll pierce the channel and you'll have a lovely leak.
If you have the parts then the process is as easy as undoing 8 screws, mounting the fans to the other side of the rad, doing up 8 screws and then doing up another 8 screws on the top to mount the rad to the case.
Changing the fans for quieter versions would help a lot. Depending on the AIO you have, some stock fans can be very loud. I've changed the fans on the NZXT Kraken and Triton that I have here as the stock ones were loud
Thanks the replies, Ive already set the fans to Quiet mode using the Gigabyte app, will have a look and see if i can manually change it.
Im sure the fans are pulling air in, i set the fans to full speed and couldnt feel any air coming off them.
I had a closer look and unscrewed the 8 screws holding the fans and radiator to the case and i see now what you mean about needing 8 more screws once the fans are mounted to the radiator, at the monment the fans are just being sandwiched between the case and radiator.
When i took the scews out it looked like only 2mm maybe 3mm of the screw screwed into the radiator so i dont think they are to long but i do understand what you mean. The part of the case to mount the radiator looks to be no more then 0.5mm thick.
The problem being i dont have the 8 screws needed to mount the radiator to the case. I have a Phanteks accessory box with spare case screws and M4 x 8mm screws look perfect but i only have 5 of them. I will have to test and see if they are the right size then get a few more from a hardware shop.
The cooler is a OcUK Techlabs 240mm AIO Liquid Cooler, should i get quieter fans? can you recommend any?
Doing this myself wouldnt void the Warranty would it? its OcUK standard system warranty - 3 year (24month C&R + 12 month labour)
Definitely look for a manual speed mode or somewhere where you can create your own fan curve. Failing that try speedfan. It only works with some motherboards but it is a very good tool.
Fans always pull air in through the front and out the back.
You don't need to use 8 screws for the radiator. I only use 4 on my 240mm rad. It's not like it's going to snap off.
The techlabs cooler fans are amazing once you get them down to a lower speed. I use 8 of them which idle at 600rpm and spin up to 1200rpm whilst gaming. But at full whack they are definitely too loud.
Warranty should be fine but i cannot say for certain.
This is looking down at the top of my case
