Titanic sinking theory
Caporegime
18 Oct 2002
Ireland
Just wondering if anyone else watched this on channel 4 the other night, "Titanic: The New Evidence", talks about a fire that was ongoing in the coal storage area before the ship left port that some think could have affected the steel of the hull allowing the iceberg to punch through it much easier.
Seems a bit strange they would set sail with a multi storey coal bunker on fire, apparently this was mentioned in the official enquiry back in the day but they ruled it out as having anything to do with the sinking. Its only some recently discovered pictures showing odd markings on the hull that's led to this train of thought. :confused:
http://www.channel4.com/programmes/titanic-the-new-evidence/on-demand/64665-001
Yeah I watched the documentary. Very interesting. I don't feel that the fire played a major part in the disaster though. The iceberg hit was easily enough to sink the ship. However, a large fire in the coal bunkers clearly played a small part. Seems odd that it took a century for the new information to emerge.
I'm not sure we will ever know the true story of the Titanic. The recent development of the video game turned up some interesting stuff that could potentially have implications for the old conspiracy theory of the ship at the bottom actually being Olympic and not Titanic.
As quoted from Reddit
For anyone actually interested in the "fire" theory, it is just that; a fire theory.
We've known of a fire being on Titanic since the survivors testified at both American and British inquiries in 1912. This is not new information.
Furthermore if you really want to blow this 'fire' theory to bits, the fire was in the starboard forward end of Boiler Room 6 (the boiler room nearest the front of the ship).
"But omg if the fire weakened the steel it would have doomed the ship omg omg omg." - typical conspiracy theorist.
The truth of the matter is that the iceberg opened up 6 compartments to the sea:
Forepeak Tank
Hold 1
Hold 2
Hold 3
Boiler Room 6
Boiler Room 5
At the time, Belfast shipping yard had concluded that Titanic could stay afloat with the first 3 or rear 3 compartments flooded, along with any combination of other 2 flooded. After the disaster took place, a naval architect from Belfast who worked on the Titanic did various calculations and concluded that they had actually designed Titanic better than they had thought. He surmised that the ship could stay afloat with the first 4 or rear 4 compartments flooded, or a combination of any 3 center compartments flooded.
As has been discussed above, here are the facts:
Titanic can stay afloat with her first 4 watertight compartments breached
Titanic can stay afloat with her rear 4 watertight compartments breached
Titanic can stay afloat if any 3 central watertight compartments breach.
And now for the doosey:
The iceberg opened up 6 compartments to the sea.
At the time of the incident, Thomas Andrews was well aware of the "she can stay afloat with 3 flooded" saying, BECAUSE HE HELPED DESIGN THE SHIP. From roughly 11:45PM - 12:15PM he toured the damaged compartments and took note of how fast each was flooding, how seriously they were damaged, everything he could note...he noted.
No doubt that once he saw that not only where the first 3 compartments flooding rapidly (14ft of water above the keel in 10 minutes) along with 3 more compartments flooding, he knew the ship was doomed. And thus relayed this information to the Captain.
The fire is null and void in this scenario. "oh but it weakened the steel you see! ha ha! Steel weakened = ship sinking ha ha !" No. Again, floats with 4 compartments flooded, sinks with 5. Iceberg opened 6.
Now here is where the bit with the fire gets interesting.
The stokers had been combatting the fire ever since Titanic arrived in Southampton to take on supplies before passengers boarded, and they had just extinguished the fire mere hours (I believe 6 or so) before the ship collided with the iceberg. To do this, they shifted coal that was not on fire over to the Port Side coal bunker for Boiler Room 6. It was then that they got the fire under control and everything was all well in Boiler Room 6 finally.
BUT! All of that extra weight shifted over to the port side of Boiler Room 6 caused the ship to list (lean) to port (left) by around 2.5 degrees. Passengers had even started to notice by Sunday noon. Surviving passenger Lawrence Beesley noted that as he was at lunch with a group of other passengers they noted that if they looked out the Port windows they could not see the horizon, only the sea. If they looked out of the Starboard (right side) windows they couldn't see the sea, only the sky. This would mean that the ship was listing to the left, but not by a huge margin, as most passenger didn't even notice.
edit, as a user pointed out I am going to add this here as I did in a comment down below "This is all speculation and hypotheticals beyond this point"
What makes this lean to Port important is.....the iceberg strike. The coal had not yet been moved back to starboard at the time of the collision, and so the ship was still listing anywhere from 2-2.5 degrees to Port.
Quartermaster Hitchens later testified that at roughly 11:45PM (5 minutes after the collision) that Captain Smith re-entered the Bridge and noted there was a 5 degree list to starboard (right).
Meaning that the ship went from a 2-2.5 degree list to Port to a 5 degree list to starboard in only 5 minutes.
Why is that initial port list important, you might ask? What would happen if it weren't there, and the ship had struck the iceberg at an even trim. Assuming that the force of the water caused the ship to take on the same degree of downward movement, Titanic would be suffering from a 7-7.5 degree list to starboard in only 5 minutes after hitting the iceberg.
At that severe of a list, lifeboats on both sides of the deck would find it very troublesome to launch, not to mention that they had to be readied yet. On the port side the boats would be practically grinding along the hull as they lowered, where on the starboard side they would be swinging anywhere from 10-15 feet away from the boat deck edge, pretty much guaranteeing that anyone to board a lifeboat would have to have the athleticism of a gymnast or they would simply not be able to enter.
And here is an even scarier scenario. As a ship sinks, its center of mavity is constantly changing. It moves from near the bottom of the ship to up near the top as more water floods in, this is hastened by lists. Which is why if you've ever taken a ship model, or seen videos of ships sinking on youtube they always roll over on one side.
It is now 11:45PM. Everyone on board is aware of a frightening list developing to starboard, but instead of stabilizing at 7-7.5 degrees it gets worse. As the center of mavity rises, the ship continues to roll over to starboard, eventually laying over all the way on its side where it then proceeds to sink beneath the waves at roughly 12:00AM - 12:10AM.
Why is this such a scary scenario? Besides the obvious reasons....the first lifeboat never left Titanic until 12:40-45AM. And the first confirmed wireless signals calling for help left only a few moments later. Captain Smith was not aware that the ship was doomed until 12:15AM - 12:20AM...
To put it shortly, the fire saved Titanic by causing the port list before the collision ever took place. If it had not had been for that fire, Titanic may have very well slipped beneath the waves with a 100% mortality rate, and not a single piece of evidence to suggest that she'd gone down. It would have become a ghost ship, and would likely still remain hidden on the ocean floor to this day.
Clearly CT crap. The ship has been discovered and researched. It is the Titanic and not the Olympic.
Guff
More guff.
And if I'm brutally honest, I find this all to be quite disrespectful to the memories of those who died when the Titanic went down.
I'm not saying their wasn't a fire, as Jokester has said, it wasn't uncommon. But was that enough to make any difference to the 300ft of hull damage and breach of six compartments? No, of course not and that's why the official enquiry wasn't concerned about it.
Unfortunately can't find the thread off the top of my head - one of the reference photos they turned up for modelling one of the rooms caused some discussion as some elements if verified had potential to either shoot the conspiracy in the foot or open it up again.
sounded like a plausible theory to me.
however after all this time it's just that, a theory that can never really be proven.
I skimmed over tres' post but have just read it fully. Very interesting and far more believable than the guff on C4 the other night.
It's a wall of text but worth taking the time to read.
The iceberg the Titanic struck was full of rocks and it was the hard jagged stones that were encased in ice that cut through the hull which was held together by rivets that done the damage. Any fire that was ongoing wouldn't have made a material difference to the ships fate.
However they had to keep filling the engines with coal because it was on fire which meant the Titanic was doing full speed when they were told to slow down because of icebergs.
The speed did have an effect on the damage.
Havent watched this yet, but have always been interested in the Titanic, so thanks for the heads up. I hope it's still on demand.
Interesting discussion about the list.
The only real question is if the ship had hit continued on course (with props going full reverse) and hit the iceberg head on would it have sunk?
We sure?
As were both ships not swapped regularly in the shipyard during refitting of one to look like the other prior to launch?
Didn't every stoker who stoked the ship refuse to resign for the transatlantic run, even with lack of jobs at the time, or was this all completely make up gubbins that just gets respouted from time to time?
