TJ07 - Good for air cooling?
Status
Not open for further replies.
There is a windowed panel available for the A70/71F, though youd have to source one somewhere.
http://www.lian-li.com/v2/en/product/product06.php?pr_index=269&cl_index=2&sc_index=29&ss_index=111
Of course, getting the existing panel done allows you to choose your own design. The A7*'s are great for cf/sli due to the sheer size of them.
Sli'd gtx 470's here.
I got my TJ07 for £120 second hand and was so impressed with the shear beauty and quality of the case! Powdercoating should be about £80 (externals cost me £40 in glossy red) so I don't see the problem. Just gotta keep your eye out on the MM. For air cooling, you could add a front bay adapter for a 120mm fan or do what I'm doing in my mod project. It's a fantastic case, the highest quality, the best looks (while still looking refined), the best window I have ever seen. You also get the bonus of a removable motherboard tray and a rivetless construction which makes your life so much easier if you need to get it sprayed. The case only uses 2 or 3 different types and they include some bags of extras, dead easy.
Although I don't have experience in it, the ATCS840 sounds ideal for your aircooling needs and has a quality finish to it.
Grrr BTR why do you have to like a case from a manufacturer that you said that you didn't want one from?
Well i didnt like the 800D as was very very very poor for air cooling, it chipped easily And it was too heavy for me to lift. (have a bad back injury) So was a disaster of a case for me.
I thought why can't they make a baby one, and they have! Just depends on air cooling now though. Need to read some reviews !
Yeah seen that in a review, doesn't worry me.
I take it there is no way to get some 120mm fans in it?
As i have 5 brand new sycthe's 1900 rpm's
it accepts 120mm and 180mm fans in both fan mounts i run a 120mm in the roof of mine cant see how it would be bad for xfire though plenty of room one thing also is it's a very heavy case too
the 650d fans push less air than a fart btw not an issue if you add third party fans but bear in mind you can only fit 20mm thick fans in there if you keep the hdd cages at the front
http://forums.overclockers.co.uk/showthread.php?t=18299084&highlight=username_C64
many people don't like the cmaster 840 on air saying there's simply too much distance between the fans and the motherboard so not so great for air cooling
Well looks like i am back to square one again :(
Watercooling is not really an option at the moment (money)
I dont really want to buy a TJ07 is i cannot watercool.
So any other suggestions, i may have missed.
Sad panda today :(
LianLi PC-p80
Plenty good for aircooling:
It can take all size motherboards inc ATX-XL (10 PCI Ports). It is however a large case
It'll easily take watercooling should you want to get your feet wet or keep it as the ultimate aircooling case? They are a little expensive tho :(.
See link in sig for more details m8.
Status
