I'm contemplating a silverstone tj07 for a build I want to do.
I have an AX1200 psu and was wondering if I would fit a 240rad in the bottom with the 480 rad due to the extended psu.
I want to flip the mobo tray so the window is on the right side. I know you can get mods for this but I believe it makes putting a 360 rad up to (with the mod) unachievable. Is that correct or has anyone manager to do it.
I will be using the maximus IV extreme so that will only make it worse I'm sure
