So I'm currently in the market for two new monitors. For years I've used a combination of LCD's, one 22" and one 15" and I think it's about time I spent some dosh in this area.
The main uses these days are book writing, coding, and occasionally gaming. The rough budget is £1-£200 per screen, and I'd like two.
The first option I've looked at is to go full hog Dell IPS with either the P2414H or even better, the U2414H. I like both, the IPS aspect interest me, and the adjustable stand is a must, but more important the quality of both from what I can find are great, once you've gotten over the IPS bleed.
The second option is to go for a normal LED, something like a Samsung S24C450BW, or basically just any LED (I've not done as much research here as I've always figured I "should" upgrade to IPS).
So my question is, first off is IPS right for me? And second, if it is, should I stick with the P2414H, or go for the U2414H at a cost of £25 per monitor (£50 total).
Thanks all
Thanks all
