Here is the question...
I'm just in the planning phase for a new build I'll be doing in the near future. I'll be using 2 250GB Seagate SATA drives for storage, recycled from my current system. I'm just in two minds as to how to use them most effectively though. At present, I'm running the two drives as a 500GB RAID 0, backing up to a NAS box. This works ok, but the backup is slow, and I can't help feeling I don't really use my PC in a way which would warrant RAID 0. I've heard performance gains are pretty meager in reality.
The main disk performance-related uses of my PC are the odd bit of gaming (loading maps/textures), opening smallish photoshop files, and loading Windows itself. I can't really think of anything else I do that would stress the HDDs to any great extent. More to the point, I am thinking the performance gain I would notice in upgrading from my current 2GB of DDR1 (running Vista) to something a bit beefier would outweigh any gain from RAID 0 anyway. Would I be right?
So, I'm looking for some advice on whether to ditch RAID altogether. Instead, I would run everything off a single 250GB HDD. This would leave me with about 120GB free to play with...should keep me happy for quite a while. The second 250GB HDD would then be put to use as a fast local clone backup, saving a hell of a lot of time in network file transfers. This would then clone itself occasionally to the NAS box which sits elsewhere.
Does this sound sensible?
Cheers guys.
Cheers guys.
