I have just deleted 9 posts which were offering/requesting competitor information.
The purpose of these boards is the discussion of consoles, by no stretch of the imagination is it to be a hub for the distribution of competitor information via email.
This has been noted, have no doubt that you will receive a suspension if you are involved in any competitor related incidents in the future. To avoid that situation please read the FAQ and make sure you have a comprehensive understanding of the rules before posting here again.
As someone mentioned above, the new 40 GB PS3 has a new sixaxis which is the same quality as the dualshock3. I have both and you cannot tell any difference apart from weight and rumble. Plastics are the same and aiming is equally good on both.
The old sixaxis must have been a real stinker![]()
Oh it was. The plastic was so thin to the point that you could put it in front of a light and see straight through the controller (try it).
I wouldn't stop there. I'd describe it as the worst pad to a major console ever.
i got mine Saturday and although the plastic is sturdy i'm abit dissappointed with the rumble. Its not very strong - well i don't think it is, been playing Drakes Fortune and Burnout Paradise demo and it seemed weak to me. Also noticed no difference what so ever in using the sticks for aiming, for me it seems excatly the same as the six-axis in aiming.
Hear, hear.
