**TODAY ONLY! 08/07/2014** Hazro HZ30WiE V2.0 30" LED Professional Monitor & HZ27WiE 27" LED Profess
OcUK Staff
4 Feb 2013
Hazro HZ30WiE V2.0 10-Bit 30" LED Widescreen Professional Monitor - Black **CLEARANCE** @ £399.95 inc VAT
**CLEARANCE SALE, BRAND NEW WITH 1yr WARRANTY**
The Hazro HZ30WiE V2 is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30WiE V2 performs with consistency and clarity to optimise your visual experience. The Hazro HZ30WiE V2 recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30WiE V2 collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30WiE V2, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30WiE V2 offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30WiE V2 is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- Aluminum Casing
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Connectivity: 1x DisplayPort, 1x DVI, 1x HDMI & 1x VGA
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 1yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Only £399.95 inc VAT.
ORDER NOW
_____
Hazro HZ27WiE 8-Bit 27" Glass LED Widescreen Professional Monitor - Black **CLEARANCE** @ £199.99 inc VAT
Hazro HZ27WiE has to be one of their best value for money achievements yet, it is actually manufacturered by LG which can be seen via the resemblance in stand design and monitor controls. Featuring a state of the art LG AH in plane switching IPS panel with a 2H Glass Gloss coating to really bring images to live along with great connectivity such as DVI-D, DisplayPort, HDMI. This monitor is ideal for any professional user or for someone who wishes to make their games look awesome.
Specification:-
- Panel Technology: AH In Plane Switching - 2H Gloss Coating
- Size: 27“ / 68.47 cm (WQHD)
- Aspect Ratio: 16:9
- Viewable Image: 596.73 x 335.66 mm
- Pixel Pitch: 0.2331 mm
- Luminance (typ.): 440 cd/m²
- Contrast (typ.): 1000:1 / 2000000:1 (dynamic)
- Viewing Angle: 178° horizontal / 178° vertical
- Response Time (typ.): 6 ms (grey-to-grey)
- Colors / Gamut: 16.7 million (8bit) / 100% sRGB
- Connectivity: 1 x DVI-D, 1 x DisplayPort (10 bit), 1 x HDMI, 1 x RGB (VGA)
- Power: DC 4pin 120W (24V)
- Horizontal Frequency: 31.5 - 98.7 kHz
- Frame Rate: 30 - 85 Hz
- Optimal Resolution: 2560 x 1440 Pixels @ 60 Hz
- Mounting Options: VESA 100x100 (M4 Thread) / Base removable
- Warranty: 1 Years Swap Out
Only £199.99 inc VAT.
ORDER NOW
Very temping but the horror stories with these and customer care is putting me off.
In fairness only the 27" really have issues and they show up instantly, so the 12 month will cover any issue there.
The 30" have being flawless with no worse reliability than the 30" Dell's we sell. :)
That's not really filing me with confidence considering Dell have dropped their standards quite considerably recently.
I've went through 4 of their 27" screens recently and each one had to be sent back, 2 of them were worse than the original faulty one and a quick search online reveals many people have had issues similar.
If the 30" is different I may take a punt on that though. It's not possible to have worse luck than with the Dell monitors I've had.
Well on 30" models the failure rate is less than 1%, they are exceptionally reliable from both DELL and Hazro.
27/29" do have higher RMA rates for all kinds of reasons from all brands, DOA, Backlight bleed excessive, dead pixels etc.
I guess 30" panels are much better grade and are on a higher quality production line with better QC in general.
You have to remember the 30" panels are £1000 screens, our price is just pretty crazy as were clearing stocks as we believe 30" will be none existent in coming months due to 4k taking over.
So very tempted to get the 27", though I will have to buy a better gfx card to do it justice haha!
If I wasn't moving house I would snag that 27" right up. Any one have experience with Hazro? Going up from a 1080p>1440p should be quite nice.
I'm tempted to upgrade from my 23" 120hz Samsung to the 27" but reading a lot of bad posts on them is putting me off - not sure how I'd handle the jump from 120z back down to 60 either...
