**Today Only 19/03/2011 – 20/03/2011** XFX ATI Radeon 6950 Graphics Card & OCZ StealthXStream 2 600W
20 Jul 2009
The bleak North East arm pit of Britain
Today Only we have 50 units of the XFX ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card for only £199.98 inc VAT. The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11 for the best in gaming visuals.
We also have 60 units of the OCZ StealthXStream 2 600W Power Supply for only £46.98 inc VAT. The new StealthXstream II strikes the right balance between mainstream power needs and high-performance build quality to deliver unprecedented value for both gamers and mainstream power users in mind.
These stunning prices also includes FREE shipping to our loyal forum members further making the Today Only deals ever better. :D
XFX ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card @ £199.98 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- ATI Reference Design (Revision: 1) - Flashable too 6970
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 2 Years
Only £199.98 inc VAT.
ORDER NOW
OCZ StealthXStream 2 600W Power Supply @ £46.98 inc VAT
The new StealthXstream II strikes the right balance between mainstream power needs and high-performance build quality to deliver unprecedented value. Designed for both gamers and mainstream power users in mind, key features of the sleek StealthXstream II include a thermally controlled 120mm double-ball bearing fan maximum airflow at near-silent audible noise levels, exceptionally well regulated electrical noise and ripple for stable operation, an ideal array of connector types for each wattage, and excellent efficiency, converting up to a full 82% of AC to DC power at typical loads. The StealthXstream II Series from OCZ is fully compliant with the latest ATX12V and EPS12V specifications.
- Series: StealthXstream II
- Type: ATX12V V2.2 / EPS12V
- Wattage: 600W
- Fan Size: 120mm double ball-bearing
- PFC: Active
- Main Connector: 20+4-Pin, +12V Rails: 4, PCI-E Connector: 1 x 6-Pin +, 1 x (6+2-Pin) PCI-E, SATA Power 4
- Efficiency: Typical load 82% Efficiency
- Energy Certifications: 80 PLUS Certified
- Input Voltage: 100 – 240V
- Input Frequency Range: 50/60 Hz
- Output: +3.3V@25A,+5V@25A,+12V1@18A, +12V2@18A, ,+12V3@18A, +12V4@18A
- [email protected],+5VSB @ 3.0A
- Dimensions: 15cm x 8.5cm x 14cm (W x H x L)
- Connectors: 1 x Main connector (20+4Pin), 1 x 8 (4+4) Pin, 1 x 6-Pin PCI-E, 1 x 6+2-Pin PCI-E, 6 x Peripheral, 4 x SATA, 1 x Floppy
- 3 Year Warranty
Only £46.98 inc VAT.
ORDER NOW
tempted by the 6950, how noisy/quiet are the reference coolers on them?
To be honest I feel they are very reasonable however when the fans spin up they can become the loudest part in your computer. Operation is silent in windows and in games its barely audible however lengthy gaming will cause any graphics card to spin up once in a while creating a little more noise.
Ok thanks so how about comparison to a reference gtx480, my fear is using a gtx470 twin frozr everthing is gonna be noisy...
if only it was another brand of 6950 i would buy one :(
Absolutly nothing wrong with XFX, my last three cards have been XFX branded and all have been exellent.
(currently using a 4850 in this rig and still have a blast on BFBC2 and clocked it to 700MHz no problem)
Also if it's a warranty issue you are bothered about isn't the two year warranty with OcUK with the XFX cards?
When exactly does this offer expire? Midnight tonight, when the stock runs out or on Wednesday at the end of the 'this week only' offer?
