The EVGA Geforce GTX 570 is the worlds fastest GTX 570 making it faster than a stock GTX 580, pretty incredible and at 570 pricing.
Dell monitors never fail to impress, with impressive viewing angles and colour the monitor makes a perfect gaming or photo editing accomplish.
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey @ £289.98 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style. Powerful:
- Experience IPS technology, featuring a wide viewing angle with high-quality color representation for a peerless viewing experience.
- Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- Customizable: Change your energy usage settings, text brightness and color temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel.
Whether for work or for play, the Dell UltraSharpTM U2412M can deliver an unmatched viewing experience.
- Clearly outstanding: Watch your graphics come to life on a vast 24" (61cm) LED-backlit screen featuring a crystal-clear 1920x1200 resolution on a 16:10 widescreen aspect ratio so you can’t lose screen area just because your customized applications support a different resolution.
- Contrasting view: Get ready for blur-free viewing with 2 million:1 (typical) high dynamic contrast ratio and 8ms with overdrive gray-to-gray (typical) response time that helps ensure crisp, sharp and ghost-free images.
- Colorful character: Enjoy an amazing range of rich, dramatic and accurate colors, thanks to IPS technology designed to give you color consistency across a broad viewing angle and a wide color gamut at 82% (typical).
- Premium Panel Guarantee: 100% replacement of Dell UltraSharp series monitors sold if any bright pixel is found, valid within the warranty1 period.
Specification:-
- 24" (60.96 cm) viewable area
- Widescreen (16:10)
- Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
- 1920 x 1200 at 60 Hz
- 1000 : 1 (typical)
- 2,000,000:1 (dynamic)
- 300 cd/m2 (typical)
- 8ms (gray to gray) Typical
- 178º / 178º
- 16.7 million colors
- Color Gamut: 82% (CIE 1976)
- 0.27 mm
- 1x Digital Visual Interface connectors (DVI-D) with HDCP
- 1x DisplayPort(DP)
- 1x Video Graphics Array (VGA)
- 1x USB 2.0 upstream port
- 4x USB 2.0 downstream ports
- DC power connector for Dell Soundbar
- Height-adjustable stand, tilt , swivel , pivot and built in cable-management
- Flat Panel Mount Interface
- VESA Mount
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Only £289.98 inc VAT.
ORDER NOW
EVGA GeForce GTX 570 Classified 1280MB GDDR5 PCI-Express Graphics Card @ £287.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- 6 Phase Digital PWM
- 10 Layer PCB
- Voltage read points
- Core Clock: 822MHz
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1280MB GDDR5
- Memory Clock: 3902MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1644MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- DisplayPort 1.1a connector included
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- 8pin + 6pin power connectors required
- Warranty: 10 years
Only £287.99 inc VAT.
ORDER NOW
Specification:-
- 178º / 178º
- 0.27 mm
- VESA Mount
ORDER NOW
Features:-
- 10 Layer PCB
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
ORDER NOW
