It does not post on several motherboards.It gives the graphics card error code on an MSI Z77 Mpower board.It also won't post on an quad core AMD board it gives the beeps for failed card.Also it has been tried on a separate Gigabyte board and it does not post on that either gives the same beeps.Each a different setup.The fans spin but nothing.
Thanks for the update on the fault.
I have raised an RMA (Returns Number) for you and all the details have been sent to your email address, Please check that these are all correct.
By sending the item back to us you agreeing to our terms and conditions within the RMA email. If the item is found faulty then it will be refunded for you or replaced whichever you want.
If you need me to send a pre paid label for the products return as well then I will gladly do so.
I hope this helps
Bailey
