CM Storm Sirus 5.1 Headset - Black @ £34.99 inc VAT
Built for gaming enthusiasts and audiophiles alike, the CM Storm Sirus 5.1 Surround Sound Headset creates an immersive gaming experience with hi-fidelity sounds capes and intensified bass.
Sirus produces precise and immaculate sound through its 8 discrete speaker channel pairs of front, rear, center, and sub; delivering accurate real-time 360 degree audio that is fully adjustable through its tactical mixing console. In addition, Sirus is coupled with a uni-directional microphone that minimizes background noise pickup enables crystal clear conversations with teammates and enemy combatants.
• True 5.1 Surround Sound (4 high quality speakers on each side)
• On-The-Fly Rear, Center, & Front speaker control for maximum sound customization (in USB mode only)
• Interchangeable ear-cups, micro weave for breathable audio and leatherette for improved noise insulation
• Dual gold-plated USB Connectors for improved signal quality
• Extra long durable and flexible microphone arm with LED mute indicator
Only £34.99 inc VAT.
ORDER NOW
Edifier C2 Plus (EDIHCS2330) @ £40.00 inc VAT
This 2.1 multimedia system by Edifier is comprised of two wooden enclosed satellites and a 61/2 inch subwoofer all supported by an independent amplifier with controls for power, bass, treble, input and volume. The HCS2320 incorporates the patented technology, Edifier Intelligent Distortion Control, a microprocessor that reduces distortion at loud volumes, which allows listeners to crank up the volume without any risk of output overload. Connect to an array of host devices using the 3.5mm to dual RCA connector cable or auxiliary input, while controlling your audio output via the wireless remote.
Features
Independent amplifier for superior control
MDF wooden enclosure for satellites and subwoofer ensures optimum sound quality
6½ inch magnetically shielded subwoofer designed to deliver deep and power bass audio output
Two-way satellites including 3 inch midrange speakers and ¾ inch tweeters
Use of Edifier Intelligent Distortion Control (IDC) patent technology to dynamically manage input overload and avoid audio distortion
Built-in headphone jack on amplifier; volume control on amp also controls volume for headphones
Microprocessor controlled system with digital display panel
Dual audio line-in, enabling connection of two audio inputs simultaneously
Specs
Power 35 watts
Power (RMS) 18 watts
Signal to Noise Ratio (less than) >85 dB
Input Sensitivity Satellites: 300mV ± 50mV (PC), 300mV ± 50mV (AUX) Subwoofer: 150mV ± 50mV
Input Impedance 10,000 ohms
Audio Features Subwoofer / bass unit: 6½ inch (166mm), Magnetically shielded, 4O • Midrange / high unit: 3 inch (78mm), Magnetically shielded, 4O • Tweeter unit: ¾ inch (20mm), PV membrane dome, magnetically Shielded, 8O
Form Factor Speaker System
Case Colour Black
Enclosure Material Wood
In The Box Amplifier • Subwoofer • 2 satellite speakers • Remote control (RC30) • 3.5mm to dual RCA connector cable • User's manual
Width 7.2 cm
Depth 21.3 cm
Height 22.3 cm
Weight 8.8 kg
Subwoofer Width 24.6 cm
Subwoofer Depth 27.1 cm
Subwoofer Height 25.2 cm
Satellite Width 9.0 cm
Satellite Depth 13.7 cm
Satellite Height 18.1 cm
Only £40.00 inc VAT.
ORDER NOW
ORDER NOW
Features
Specs
Power 35 watts
Case Colour Black
Width 7.2 cm
Depth 21.3 cm
Height 22.3 cm
Weight 8.8 kg
ORDER NOW
