Tofu eaters
27 Aug 2009
How do you press your Tofu??
We have started eating it quite a bit (now a few times a week), but find the pressing such a pain in the hinney. All those sodden paper towels and mess.
This looks great http://tofupresser.com/
has anyone got anything like this? Where did you get it as i will have to have this shipped from USA.
Or, any better ways to press Tofu??
Thanks
Then I get a steak out.
What Justin said should work though.
I've cooked tofu a few times and it's always confused me. The fresh stuff comes in water and is a total bitch to cook with because it's full of water and breaks up when you stir fry it. The other stuff is pre-fried and much tougher. Are you supposed to press the water out of it before you use it then? How much are you supposed to squeeze out?
Yes, press it for 1 - 2 hours for best results and it will draw the liquid out and give it a very firm texture. It will be like a sponge now and absorb everything. If you are marinating it, press it then dry fry it first and it will take on even more flavour.
I didn't know you had to press tofu! I wondered why the fried tofu is a lot firmer. I've never cooked with it myself, but when my rents buy/cook it, they buy fresh tofu and just bung it in a soup.
I don't really like it like that. Fried tofu all the way :)
I find it best to squeeze it with a ton of plates and bowls on top, then cut to small cubes and fry in a very very hot pan.
Just need to find a tofu press to cut down the mess!
You don't have to press the tofu, it depends on how you're cooking it. If it fresh, it's pretty tasty in clear broths/soups.
If you're doing a stir fry, the pre-fried tofu is a better option.
Has anyone had the cubes of tofu you get mixed in with wagamamas?
What would be the best stuff to get to replicate this? I bought some wet tofu a while ago and like jonny, it crumbled when I mixed it in to a stir fry!
Second go I fried it separately beforehand so it toughened up a bit and then added it. Still not great though... Should I be buying pre fried stuff?
