Tomb Raider (2013) mouse stutter problem
controller or don't bother in this game. You used to be able to use keyboard and moues in the old Core Design games as the movement was grid limited. We're not in 2003 any more though. The pad comments are all relevant as frankly you're ruining your experience of the game by attempting to use a mouse!
i had this problem, you have to turn off tessellation in advanced options.
well thats what worked for me !
I find that the mouse movement isn't the greatest in this game myself. Feels more like input lag than stuttering though. Disabling SSAO (and vsync ofc) seems to help but I just put up with it for the most part though :D
None of these things work. As I said, the actually game is running perfectly smooth because when you just use keyboard to move around it is silky smooth. It's just the mouse that's causing stuttery movement.
I don't mind playing with a controller, but honestly, apart from comfort (and even that is debatable), I don't see any benefit in playing with a controller over a mouse and keyboard. Other third person games work perfectly fine using a mouse (e.g. Alan Wake), why doesn't this?
I any case, if it is a known issue with the game and mouse control, then that's fine, will save me chasing a non-existant solution!
