Tomb raider high cpu usage
26 Nov 2008
Leeds
What sort of cpu usage are people getting inn tomb raider? I'm getting 100% nearly which im told i shouldn't be.
Angst has a 2500k and a 7850 crossfire setup.
Thanks matt, Yea a 2500k at 4.5ghz. I get 120fps and 99% gpu load most of the time @1080p with max settings apart from using fxaa and tressfx disabled. The problem iss i get massive fps fdrops to between 20-60 everynow and then.
Have you checked task manager while playing to make sure another process is not hogging cpu cycles like a virus or something?
Just checked and nothing else is running its all tomb raider, ill try it with frame pacing off see if that makes a difference to cpu usage.
Edit: frame pacing makes no difference.
