- 11 Mar 2016
Hi guys
I saw doom 4 (due MAY) and had to build a new PC.
So far I have ordered..
Lian Li PC-O8SWX ATX Cube Case
Maximus VIII Formula Intel Z170
Core i7-6700K 4.0GHz (Skylake) Socket LGA1151
Dominator Platinum 16GB 4 x 4GB
BitFenix Alchemy 2.0 PSU Cable Kit - Red
Corsair HX1000i
Samsung 950 Pro 512GB M.2 PCI-e
EK-Supremacy EVO - Nickel Water Block
Pipes and fittings
2 x Resivour Fitting
3 fan EK-Vardar F3-120
EK-Cable Y-Splitter 2 fan
PrimoChill Vortex - Clear PMMA Flow Indicator
EK-CoolStream XE 360 60mm
EK Water Blocks EK-CoolStream PE 240
3 x EK-Vardar F3-120
EK-Cable Y-Splitter 3 fan
Arctic Silver 5 Thermal Compound
Some bits have turned up - awaiting delivery on some others...
Theme is going to be a mix of red/black/silver
I have yet to buy the reservoir for the system and pump but thinking along the lines of
EK-XRES 140 DDC 3.2 PWM Elite
coolant concentrate:EK-Ekoolant EVO Clear
EK-RES X4 250
EK-UNI Pump Bracket (120mm FAN) Vertical
EK-AF FillPort G1/4 - Nickel
Corsair HX1000i
Pipes and fittings
EK-RES X4 250
