Tool storage
22 Oct 2005
Moving...
I've currently got a 28" Stanley Fat max toolbox. It's full to the brim with random tools which makes finding things a bit of a nightmare. It's also bloody heavy. On top of that I've got separate cases for various power tools, and a couple of crates with random things that won't fit in the toolbox (sandpaper, caulking guns, ppe, etc).
I need to up my storage game.
I like the idea of nice big tool chest, but I'm not sure I can justify the £250+ it costs for a decent sized one. Also, a lot of the trays are very shallow, so I might still end up with a crate or two for the bulky stuff.
The alternative is to just buy more tool boxes and separate it out (possibly one of the stackable options). The idea of having to unstack them to get at things would annoy me though, and they're tricky to organise.
I've got a garage to store it in, but I don't have loads of space, so spreading it out over some nice shelves/pegs above a workbench is not an option.
Any thoughts/recommendations?
Ive got loads of Dewalt Tstak boxes with shadowfoam insers that are cut to neatly store and protect my tools. Still need to sort more but doing it slowy and on a budget
you can pick 2nd had tstak boxes up on facebook marketplace for as little as £10 each
The previous owner had put a kitchen unit on the garage wall which having walked into it a couple of times, deemed it quite dangerous. I knocked the sides, bottom and top off and used a couple of dozen cup hooks screwed into the timber back for hangable items, spanners, wrenches, tenon saw etc. A cheap and cheerful solution.
A large ply board set off from the wall half an inch would be similar enabling trowels and similar to be slid in at the top. The hooks I bought from IKEA twenty years ago and never used.
What's your DIY-ing like? I made a couple of c500mm cubed drawer units to go on a costco shelving unit. Drawers much easier to find things than crates/boxes etc. My tools are mostly going into Makita MakPacs because I had some to start with and you can get the size 3 for £13. I had some spare ply so the first 2 drawers were free.
Mix of 12mm and 18mm ply - the drawer bases take up to most material. No drawer slides needed, just use offcuts of 12mm to make gaps the bottom of the drawers slide in.
This guys are way posher than mine, but the method is the same
I have spent the last 3 weeks or so cleaning and tidying my garage out to accomodate more tools.
The one thing I have found is if you have a lot of storage you won't throw anything away. - I have still kept stuff that should have been dumped years ago.
I have a large toolbox on wheels and it is full of 240v power tools but I can't throw them away. We moan at wife for keeping rubbish but we do the same - It's not really rubbish is it - you can still use them for what they are designed for except you have loads of battery tools you now use. :D
I split a lot of my stuff up into separate boxes. Either individual toolboxes (the Stanley plastic ones are good) or stackable lidded boxes (Really Useful Boxes are great for this).
So I've got a small toolbox with electrical stuff in. Insulated screwdrivers, wire strippers, test meter, electrical screws, fuses, etc.
A medium box with bike maintenance stuff in. Bonus that I can just bung that in the back of the car if I'm off on a ride somewhere.
Then things like plumbing tools and spares in a lidded box. Same with car repair tools I use infrequently (like spring compressors).
Exactly what I do.
All my tools are in various boxes. I have a lot of TSTAK and various other makes. All my tools, apart from garden tools, are in boxes. Most of my tools were bought in the boxes they are in, but some I used TSTAK and foam inserts. Garden tools are on the garage wall.
I do have draws for the hand tools I use often, but the rest go in boxes. Boxed per trade, so I have three boxes for plumbing, two boxes for PC work and so on. On top of that, I have boxes for screws and other fittings.
Storage is so important. I won't buy a tool unless it comes in a box, lol.
Yes, those Stanley boxes are very good. I've lost count of how many of those I have. I've even made special shelves to stack the boxes from floor to ceiling, lol. I use the full height ones for screws and the half height ones for odds and ends. They are a bit heavy when full of screws, but they are strong enough to cope.
I've got a mixture of TSTAK & ToughSystem boxes for most of my gear. I prefer it to fixed cupboards etc, as when doing DIY in a particular room, I can bring the boxes I need with me, rather than coming back tool by tool.
Yea, I've got a FatMax tote bag that I tend to fill with all the tools I think I'll need for a job and then cart that into the house. Useful also as it just fills up with tools, which I periodically tidy back to where they should go, so I at leas know they've all been dumped in one place and are reasonably tidy.
Looking forward to the prospect of sharing my new garden room 'shed' with my wife. Let's see how long it remains even remotely tidy..! :D
I've got a load of TStak boxes which are great but as the OP says, you generally need something from the box at the bottom of the stack.
There's a few options for wall mounting which I want to investigate further eg
https://www.etsy.com/uk/listing/1610388525/dewalt-stanley-pro-slider-brackets - so you can put the parts organisers onto rails
https://www.screwfix.com/p/dewalt-toughsystem-storage-racking-1800mm-70-/6251T? - not sure if this fits TStak or just ToughSystem
One thing I picked up from my dad was that rather than have one or two general tool boxes it's better to have multiple specific ones if you can, so in an emergency you can go and just grab the bag for the emergency and potentially if needed something like your drill.
For example we have a "general DIY" tote that has a handful of common screwdrivers, a set of screwdriver, a set of common drill bits, a couple of adjustable spanners, mini level etc in it, we then have specific one for electrical and another for plumbing that contain the most common tools for them and a small number of spares, we then have a couple of pull along tool boxes that hold the bulky spares for plumbing and electrical stuff*.
A little tip, if you ever intend to do plumbing work, as well as the obvious tools get some open ring spanners, they're like the love child of a normal spanner and a closed ring one, you sort of get them onto the nut by placing the opening over the pipe then slide it over the nut and it grips partially behind the nut, so you get a better grip than a normal open spanner you normally get them to fit the 15mm and 22mm pipe fittings and they are a godsend when you can only turn the nut 1/8th or less at a go.
All the "quick grab" totes have pencils/markers/mini levels etc in them so there is a fair bit of duplication but it means you're not looking for where your measures/levels etc are as they're in every box/tote. The idea is no one bag/tote weighs much (apart from the plumbing one, as that's got so many big spanners and specific metal tools), but has most of the stuff you'll need for that type of job.
The downside is it all takes space, and costs money, but the upside is you're not spending a lot of time finding the tools when you need them "now" and there are times when the duplicates are extremely handy (my dad is a great believer in buying at least two of any spanners for example**).
We also have a couple of metal "garage" tool chests with drawers where things like spare and unusual sockets and spanners live (you can get rubbery type mats to help hold them from moving), and a more common/bulky tools like saws are on pegs or magnetic rails on the wall (magnetic rails are ideal for things like screwdrivers, set squares and comically long SDS bits).
We do have rather a lot of duplication in terms of tools, and a lot of very rarely used tools, for storage for them we have some of these in grey (I think that was the only colour at the time) for a lot of them, which are very handy for storing things that you need a lot of variety of but are small/light, so for example one drawer that's got various marking and related items (pens/pencils, erasers, sharpeners etc), another that has measuring & mini levels, and to hold things like small sets of router bits and so, and another that has things like a variety of disposable knives/spare blade packs, or spare sanding sheets and pads.
I say all this and i'm very aware we've got a lot of tools in our garage that are extremely rarely used, and some that were bought because we needed them at one point but didn't know, so when we saw it at a good price we picked them up. Things like olive cutters and pullers for plumbing - you don't realise how much you need them until you've spent 45 minutes or more trying to cut off an old olive in a space where you can only move the hacksaw blade (with no handle) an inch at a time ;)
My dad's been buying these odd tools for over 60 years and it's caused some amusement with neighbours when they've had an issue that's stumped them and my dad used to go "give me a few minutes, I've got a (very specific) tool for that, I needed it to fix my old combination bike" or similar.
*We tend to buy spares/multipacks of common stuff, so the general plumbing bag will have maybe one or two of most fittings and some short bits of pipe as well as the tools, but the big ones might hold bags/packs of say 10 fittings, or larger fittings that aren't needed as often.
**And having a wide variety of spanners for the same size, for example the obvious open and closed ones, offset ones, flat ones, ones that have ratchets built in, ones that can have the end turned up to 90 degrees either way so when you can only get the spanner on at an angle normally you can get the head onto the nut/bolt properly with the handle at an angle.
I'm not sure what tools y'all talking about to go straight to boxes. I have a circ, sawzall, and angle grinder box and that's it. Anything needed more than a half dozen times lives in a Stanley open tote so it's grabbable and easily accessible. I then have an old stack box black and decker thing with long term tools in. I do have the cheapie tough boxes from Wickes for storing bits and pieces I guess, where highly specialised stuff lives (slightly contradicting myself therefore).
Carwise I agree it's all boxed up - Halfords pro box I bought when I was 17.
I am interested by these wall mounts tho! That would be cool to have the boxes act as storage and shelf units - really annoying having to derack the box and get what you need. Unfortunately I don't want to dedicate the wall space to it.
I have inherited a big box of spanners so sorted some out today. This is now a heavy box of Snap-on spanners and sockets -must be worth a few quid.
Only drawback is they are all AF/Whit - There are some metric spanners but put them in another box.
Regarding the post above you must have gaffa tape in your toolboxes - along with other sorts of tape and cable ties.
The Af/Whit are exceptionally handy with American or older british stuff, my dad has a bunch in the toolboxes although not that many these days as his van got broken into in the 90's and he lost most of his car tools from the 70's.
Yup tapes/ties/a roll of string, couple of pencils, markers and so on.
For anyone near a Homebase, as they're shutting down/rebranding the stores to The Range everything is being reduced so things like the Stanely Totes are something like 20-40% off now, and they're quite handy for grab bags of tools (I use a couple of Aldi special buy ones from ages ago, they've lasted about 15+ years with ease), as you can drop larger bits in the main section and IIRC they have some pockets and holders for things like spanners/hammers/screwbits.
I've probably spent more in homebase in the last few weeks than the last 10 years, including things like extruded aluminium shapes which were already very heavily reduced then half price (30mm x 2mm x 2meter for £1.50) similar for steel bar, a couple of adjustable height work platforms that were something like 20% off.
Although I'm being careful not to get anything that is either too expensive, or doesn't have a manufacturers warranty to fall back on ;)
Yeah I saw this video and was thinking of doing the same but more realistically for me after having a look on Facebook marketplace I'm tempted to just get free drawers and modify them.
I just watched that video and it has inspired me to try making a set of hobby drawers for my desk, rather buy and Ikea Alex. Will have to wait until the new year and better weather though. #need-a-shed-or-workshop
I think tool storage is the most important thing to spend money on when you have tools. You need to know where everything is. You also need it protected, especially from damp.
Always buy a power tool that comes in a case!
I mostly use TSTAK cases for general tool storage. It's quite unbelievable how many I have.
Good time to check Homebase right now with their closing down and or change to the Range.
Last time with the failed Bunnings, we saved a lot of money and noticed much of the tool storage and cabs were dirt cheap.
stuff*.
just started that and aside from main tool cabinets i have go to bags for plumbing /house electrical etc. then lucky enough to have some 4 draw filing cabinets ,so can designate a drawer to plumbing joints (copper) , one to electrical sockets switches etc and so on , makes finding stuff easier.
