Toothpaste as thermal paste
Permabanned
21 Oct 2010
I've just dug out an old intel pentium d and applied toothpaste as thermal and I'm getting readings of 26c. How good is that? :eek:
regardless of short term results the toothpaste will dry, shrink adn break downa over time... almost any substance you can manage to squeeze under a heatsink should work to some degree for a time...
p4d at 26 degrees.. are testing it outside in antartica?
I'm using AquaFresh. Now I've seen it works Ok I'm gonna use it on my new CPU until I can pick up some ArcticSilver.
26C is lower than ambient temps here today!
I certainly wouldn't try it on a new processor, unless you want it to fail when the paste has dried up (fairly quickly!)
