you cant go wrong with an fx8320 the rig in my signature plays battlefield 4 maxed out in 1080p at 65fps. i also would agree for the spec you listed the golden green 550w would be enough. i cant argue with that motherboard choice either its 8+2 phase power so should be fine.
the r9 280 wouldnt be too far off gtx770 performance either as the r9 280x is about equal to it.
i also 2nd the comment about ssd i run bf4 off my ssd and im nearly always first on the map with a countdown timer watching the other players spawn as they join. it makes a huge difference to boot times (mine takes about 40s and i have to put the password in twice), software installation times and many other things.
. Ill be playing at 1080p and the upgrade to 1440p at december time. I wont be upgrading the cpu until 2016 though (and possibly the mobo).
