You can removed the ads.
http://i.imgur.com/lLaOS.png[IMG]
Google is your friend.
Write that down on a post it note and stick it on the monitor bezel.[/QUOTE]
Thanks for that, didn't know about it.
Is there any truth in the v3 of uTorrent containing behaviour tracking code?
It wouldn't be of any concern to me as I only use torrents for BBC radio shows but it is something to be aware of for those who use torrents for sourcing other materials.
Just upgraded to the latest version (after carefully checking each part of the download & install process and unticking / choosing no to the extra unwanted crap) and it has a logger tab.Do the newer versions have the Logger tab? I tried one a while ago and switched back as I couldn't find anywhere to view the log.
Deluge has a wide-array of features, including:
Core/UI split allowing Deluge to run as a daemon
Connect remotely to the Deluge daemon
Web UI
Console UI
GTK+ UI
BitTorrent Protocol Encryption
Mainline DHT
Local Peer Discovery (aka LSD)
FAST protocol extension
µTorrent Peer Exchange
UPnP and NAT-PMP
Proxy support
Web seed
Private Torrents
Global and per-torrent speed limits
Configurable bandwidth scheduler
Password protection
RSS (via Plugin)
Other libtorrent features
And much more!
