encephalopathy said:here is a solution that worked last night for my mate on pipex (they are throttling p2p at 20k)
use utorrent or azureus as your client
make sure you turn packet encryption ON
his d/l rate went from 20 to 100k almost straightaway
until such times as they prioritise encrypted packets as low priority this should work
hope this helps
Read about this on the ADSLguide forums. Using Azureus here and thought I'd give it a go. Still sat around 25k/s on a very well seeded torrent. I'll throw a few more at it and see what happens.
EDIT
Right, tried a different torrent and it hit 170k/s which is nice. Me being an enquisitive type wondered what would happen if I turned encryption off. Now it's going even quicker. Either I'm not actually being throttled and it's a coincidence my torrent was doing about 20 - 30k/s or it's only throttled at certain times and I've just hit off-peak.......
What do you think you pay your ISP for? They are there to provide a decent quailty of service for *all* of their users. So all ISPs will be monitoring their traffic and shaping it in some form. Some do this as caps, some throttle excessive services, others block ports. Usually all detailed in the T's & C's that no one reads.
