squiffy said:Yes, however you want to make sure the digital out is ASIO compliant. M-Audio Revolution is, as 44.1hz PCM is sent as 44.1khz PCM, and not 48khz. 48khz is sent as 48khz. Some soundcards will always upsample everything to 48khz.
squiffy said:ah right sorry it lacks optical out. Does your av amp have electrical SPDIF?
