Total novice here!!msiZ87 gd45+i7 4770k+corsair vengence red 2133 mhz
1 Nov 2013
Hi 8 pack first post so here it goes.
Basically i'm a novice when it comes to overclocking and i'm trying to achieve certain clock and ram speed for playing guild wars 2. it seems that guild wars 2 achieves better frame rates every time i up the clock speed by 100 mhz.
What i have achieved so far:
pc will boot with 4.3 ghz and ram set at 1800 nothing else changed and will run all day on any game.
But that is all i know how to do. up the multiplier and set the ram until it fails to boot. this seems far from achieveing optimal performance though
i have no understanding of ram timings so could you explain that to me?
i have no understanding on adjusting voltage either.
what i would like to achieve:
4.5 ghz and ram at its rated speed at least. and then learn how to fine tune timings though i'm not sure what they actually do.
sorry if any of this is vague if i have missed anything let me know
Thanks
what voltage are you using for 4.3???
Update your Bios first!!!
For 4.5 with 2133 RAM
I would enable XMP first. This should set up the RAM automatically.
Set Multi to 45 and Core Voltage to 1.25.
Set Ring Voltage to the same and set Cache multi to 42.
Set DRAM voltage to 1.65 and add 0.1 to SA, IOD and IOA.
Now test!!!
WOW!!!! all worked perfectly. May have upped multi to 46. All my benchmarking software worked flawlessly and the main reason for overclocking, guild wars 2, has seen a HUGE performance increase!!!
Perfect! what a ledgend:D
Cheers 8 pack!
