totally confused with pc problem
20 Oct 2012
I am needing help. I installed eazytune on my pc to try a little over clocking etc. And after I selected an option the pc shut down and I thought it would restart but all I am getting is I can hear the fans running but nothing showing on the monitor. I hope I haven't fried my pc.
Not sure what to do next to get it working
Clear the cmos if you still have the book it should tell u were it is.
It might be a button or jumper depending on motherboard and make.
Then if it comes on will ask you to reset all settings if ur unsure on any u might have to post here again
Thanks for the help I found some articles on resetting the BIOS and I done what the easiest one I could understand and I ended up removing the battery on the motherboard and then put it back, and thankfully we had it power backup.
Think I will not meddle anymore with over clocking etc lol I was totally stressed out
It's allright. Just short the CLEAR_CMOS jumper for a few seconds.
You may be able to save your BIOS profiles to disk before trying anything... so you can put back your settings afterwards.
