Totally stuck on Stalker
18 Oct 2002
Kent
I bought Stalker the other day as it was on offer and i've finally ready a point i cant get past. I've found the documents from the X18 lab but i have no way out as the screenshot below will show.
Can anyone help me out?
Cheers.
Scream at the door and it will just open.
For normal advice from me - you'll need to post in the right forum :) :p
Have you asked nicely? I mean, it does say the door is being held.
Maybe the person on the otherside can be coaxed out by some flowers and a box of choccies.
Actually I think it's you (the player) that is holding the door - and since the door is an automatic door - you're effectively holding the door closed. Let go of it and it should open :)
If that's the lab bit whith the crazy things in the jars one of them escaped and you need to kill it, should be a "cloud" thing floating around the room shoot it lots but dont let it touch you.
You have to kill that thing that keeps setting you on fire before it opens .
looks like a moving fire anomaly.
