Touching up scratches.
29 Dec 2004
Shepley
I've got some small scratches on my bumper which I managed to scrape on the gatepost reversing the car, what's the best way to cure it? They don't look T-Cuttable.
Best to start off with the least abraisive polish and work your way down to the most abraisive, ie, T-cut or Paint Renovator.
You can get some touch up paint from Halfords, just take a note of the paint code from the VIN plate. If you're not sure get one of the people there to help you out :)
You can get some touch up plate from Halfords, just take a note of the paint code from the VIN plate. If you're not sure get one of the people there to help you out :)
Will have a look in Halfords. The scratches are actually really small but a couple of spots you can see primer so better safe than sorry.
Sometimes better going to your car manufacturer for the touch up paints.
I got a Peugeot on last saturday for £4.20. Proper OEM touch up paint (thicker than the Halfrauds ones).
Sound advice, they are a much better paint match and i've found better quality, another shock is they are sometimes cheaper!
Awesome! I need to get some touch up paint actually, my car has a load of stone chips and markings :(
I was shocked as well.
Considering that the same dealer tries to charge me £27 for a single windscreen wiper for my 307. (oh i did laugth)
Got 2 on ebay for £6.50 each Bosch.
