Thanks for your thoughts.
They are 205 50 R17
Still overpriced?
Is this a MK1 Focus (1998 - 2004)? If so shouldn't you be using 215/45 R17 instead?
Its a 2008 plate
Hugely overpriced!
Hankook V12 EVO in your size is around £60-£70 each and its a superior tyre.
I think Toyo T1R's are about £55 in your size.
Try over £100 for both!
Out of interest, who is trying to blag £120 for 2 part worn tyres in that size!? Thats totally out of scope with the industry.
Some local tyre fitter, i rang up to get a quote for some Falken 452's and they said they didnt stock them and tried to upsell me those instead.
Time to ring a different fitter!
Ha ha, it isnt my usual fitter - just some random one who wont be getting my business![]()
[TW]Fox;18388503 said:Don't forget some part worn brake pads as well.
Not suggesting you buy these, but just to give you an idea of used tyre values, first hit on google were these:
http://cgi.ebay.co.uk/2055017-PIREL...20981?pt=UK_Cars_Tyres_RL&hash=item2a0dd26e15
Very good premium tyre with "lots of tread" (in used terms 4mm looks like a lot visibly, i doubt those toyo's were much more)
Thats the kind of value used tyres have for future reference if thinking about buying them. You'd want more tread than those have, they just serve as a quick example![]()
Oh indeed. Either way you dont want to overpay. I'm sure the guy will eventually get that £120 for those toyo's off someone. Least it wont be you.
