Got any trackdays booked yet?
My next one is end of Jan. Nothing more than an aftermarket oil cooler and R888s for me.
I may have an MS1 V3 if you are intersted?
I love ITB's! Did yoy just cut the original intake manifold down and use silicone tube to connect up these bodies?
Just wanted something a bit crazy to match the character of the car, as I said we're not taking the styling too serious so expect lots of stickers and random paint.
I've not seen a Puma at trackday so it's nice to see something a little different.
can you put ITBS of a bike on a DBW car ?
Possibly, I'm guessing you would need some sort of actuator to mechanically open the throttle based on the ECU's outputs.
), the bodies, manifold bit and butterflies themselves are relatively cheap but the calibrated stepper motor assembly you need to move the throttles is the expensive and complicated part, not exactly standardized or readily available either, where available it seems to have been designed and developed from scratch rather than just bought from jenvey or whoever else with the rest of the bits. Cable throttle is easy peezy...one ponders whether converting to cable throttle and running a relatively basic aftermarket management setup would be almost comparable to the price DRM charge for the Fiesta.This is why its so expensive to put throttle bodies on the Fiesta ST (£2800), the bodies, manifold bit and butterflies themselves are relatively cheap but the calibrated stepper motor assembly you need to move the throttles is the expensive and complicated part, not exactly standardized or readily available either, where available it seems to have been designed and developed from scratch rather than just bought from jenvey or whoever else with the rest of the bits. Cable throttle is easy peezy...one ponders whether converting to cable throttle and running a relatively basic aftermarket management setup would be almost comparable to the price DRM charge for the Fiesta.
Think I might do this on my daily...Are you going to move your oil vent for your rocker? I wouldnt want it that near to my air filter. Can you re-route it into a catch tank or something?
Great work, i do have a soft spot for these cars!
