- 13 Jul 2004
- Stanley Hotel, Colorado
A twin cam D series Honda engine will have similar power to that 306. Single cam is a bit less, 115bhp abouts
They came in the honda civic and some other models. Hondas can be expensive because of their reputation to last but I have seen them go cheap
Concerto is one unpopular honda model, 135bhp and should be going for a hundred or so since they are all over 10 years old now
Also it was an engine used in the rover 200, again available for hundred(s)
If its just a track car, why dont you get something thats failed an mot like an old bmw with abs failed or something. You can easily get a 7 series for under a grand with a short mot, so I bet any model in their range is available under similar circumstances.
CRX is overvalued imo, the only ones cheap enough will be the ones with a d series and you might as well get what I said above. It is very light of course
http://atsearch.autotrader.co.uk/ww...&ukcarsearch_full.y=6&ukcarsearch_full=SEARCH
http://atsearch.autotrader.co.uk/ww...&ukcarsearch_full.y=9&ukcarsearch_full=SEARCH
