I had this problem also(with nearly every starforce protected game), you just disable it in a couple of places in device manager and thats it, you should never have any problems again, you should still be able to use your keyboard, don't disable your keyboard under "keyboards" in device manager, instead go into "human interaface devices" and right click on all the "usb human interface divices that are there, click properties and check the location, if it says "(usb Gaming keyboard Pro) then disable the device, I think there are 2 that you can disable, this will just take the keyboard out of the game controller interface but still function as a normal keyboard.
