I just need someone to verify this as I am pretty sure, BUT
if I transfer two striped hard drives, raid 0, onto a new motherboard, cpu etc.
Is it possible to plug in the drives, set up the RAID again, and enable the drive in Windows, and instantly have access to all the data OR will I be best off just backing the data up, formatting the drives setting up a new RAID and putting the data back onto the drives?
I am currently on a nforce4 chipset and using nvidia's onbard RAID chip, and I will be moving to a X58 1366 board, as the mobo's RAID chipset's are different I believe I will have go down the second route and format the drives. If anyone has any experince on this or has a definitive answer, please enlighten me.
P.S. this is largely an academic argument as I am going to back up all the data anyway before transferring, but it got me wondering...
if I transfer two striped hard drives, raid 0, onto a new motherboard, cpu etc. Is it possible to plug in the drives, set up the RAID again, and enable the drive in Windows, and instantly have access to all the data OR will I be best off just backing the data up, formatting the drives setting up a new RAID and putting the data back onto the drives?
