- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Something a little different to tickle your fancy
AeroCool Strike-X Air Open Chassis @ £84.98 inc VAT
The new Strike-X AIR is a brand new PC open case concept fully developed by Aerocool's design team that will make using the PC a brand new experience. Its open structure is designed in a way so that it is easy to access the internal components making it extremely to install and/or uninstall components.
The supplied 200mm red LED fan can be positioned in three different ways depending on the desired cooling and installed components. For maximum cooling the closed location is recommended because it puts the 200mm fan as close to the motherboard as possible. The only downside with this is that it limits the maximum height of the CPU cooler that can be used. Positioning the fan in any of the other two locations would virtually remove this limitation.
No matter what type of user you are and which components you decide to install in the Strike-X AIR chassis, it's guaranteed to turn heads as there is no other case on the market that comes close to the uniqueness of this chassis. The chassis is in limited supply so don't delay, get one today and be the envy of your friends!
- Material: SECC 0.7mm
- Motherboard: Micro ATX / ATX / XL-ATX
- Case dimensions: 340mm (H) x 613mm (W) x 535mm (D)
- Drive bays: 3 x 5.25" (Exposed) / 3 x 3.5" HDD or 2.5" HDD
- Expansion slots: 10
- Max. length space available for PCI slots: 330mm
- I/O ports: 1xUSB3.0/3xUSB2.0/2HD AUDIO
Only £84.98 inc VAT.
ORDER NOW
ORDER NOW
