Transporting water cooled PC
13 Aug 2011
I recently purchased parts from OCUK to the value of £5500 and built a monster PC which I'm now selling.
As it's obviously worth a lot of money, I would prefer collection. However, I'm also intending to ship it. Does anyone have any tips for when shipping it as I'm scared it may leak? Any recommended couriers to use etc?
Thanks
Thanks
Expanding foam is a god send!!!
if its hard tubing... drain the system!!!!!!!!!!
at least use the double box method.... order a bigger box and line if with the other part boxes with the case box in the middle.. if your selling it for £3k- id expect it to be in a create!
selling it as a whole- you might lose out rather then selling in parts
It's hard tubing but I'd prefer not to drain the system as the buyer may not know how to fill it back up etc. What's the best thing to do if I don't drain it?
I would deliver myself or let him collect.
Also, if the buyer doesn't know how to drain and fill up a custom watercooled pc, he should not buy one.
Thing with hard tubing is it's so ridged there's no give .
Thought about draining then replacing all with soft tubing and barrow fittings ? Won't cost you as much as you think, then you can use expanding foam packs and double box
This. I would not send a filled watercooled PC via any kind of courier, even if you pack it well a knock could potentially dislodge a fitting and flood the case.
I'd either drain it or deliver it yourself. Having said that, OcUK ship complete watercooled pcs with hard tubing ( https://www.overclockers.co.uk/8pac...hz-ddr4-extreme-overclocked-pc-fs-004-8p.html ). I wonder what precautions they take. Does anyone know if they come filled?
