ok my advice as a cycle shop owner ( the cycle centre oxford)
ok bare with me here and dont fee like im undermining you!
first of make sure you get your terminology right as in "Raleigh bb" cos if your gonna go back and argue with the bike shop make sure you know your stuff!!!
so.....
in the old days raleigh used to use 26tpi threads which is typically known as "raleigh bb"
modern day bb uses 24tpi.
so.. IF they have managed to fit "raleigh bb" then they have forcefully threaded the bb in the wrong threads.
now assuming they havent but just fitted a CHEAP raleigh branded 24tpi bb
when we do a job like that we replace like for like so remove sealed bb replace with sealed bb.
while removing a decent mechanic will clean threads in frame of dirt and if necessary run a thread cleaning tool through it to make sure good threads.
difference between 2 bb's are about £15/20.
now looking at the video i can see the bb shell isnt moving but the axel is, i would check the other side of the shell to see if that is moving, the problem with those "raleigh type" bb or otherwise known and cup/cone bb is they inherently come loose.
any decent shop would accept/admit fault and replace with better sealed unit and may charge you the difference (without labour)
i agree with eXist, if they dont admit, proving it was them will be hard but none the less argue till u win.
hope this helps and best of luck
so.....
