- 16 May 2011
- Staffordshire
With uni fast approaching I am planning on switching my system to an ITX format, likely using the prodigy. But I need to know what I can expect gameplay wise from a single water cooled and overclocked GTX 670 or 680 if I use a triple screen setup?
All monitors would be at 1080p and this would be in games such as Battlefield 3 GTA 4 and 5 so it is for very demanding games.
Thanks
Thanks
. With the 670s/680s you're hitting other bottlenecks which causes low FPS causing you to reduce settings which in turn removes you well away from the 2GB limit. This holds true for 2GB cards.
