Triple monitors
26 Nov 2009
I need some advice please. I apologise if this has been covered before but I'm about to purchase a 4790k and a Gigabyte Z97 motherboard and want to use triple monitors using the inbuilt gpu without a dedicated card until the next generation amd/nvidia graphics are available. Does the inbuilt gpu support triple monitors? What ports will I need on the motherboard?
Yes you can use three monitors on a Z97 board and that CPU.
The ports you need are the ones your monitors have. Not all Z97 have three outputs etec.
You can mix and match, but some ports have limtaions on resolution etc.
Take this board for example - http://www.gigabyte.com/products/product-page.aspx?pid=4959#ov
Integrated Graphics Processor - Intel® HD Graphics support:
1 x D-Sub port, supporting a maximum resolution of 1920x1200@60Hz
1 x DVI-D port, supporting a maximum resolution of 1920x1200@60Hz
* The DVI-D port does not support D-Sub connection by adapter.
1 x HDMI port, supporting a maximum resolution of 4096x2160@24Hz or 2560x1600@60Hz
* Support for HDMI 1.4a version.
Support for up to 3 displays at the same time
Maximum shared memory of 512MB
