- 30 Dec 2011
- Essex
Hey guys,
I have a cm Stryker with a h100i mounted in the roof and a gtx 770 which I plan on making a custom loop for. I heard that you can mount radiators 240mm at the bottom and a 360mm at the front with no modifications such as removing drive cages or removing PSU. Is this right?
I want to know what radiator I should get for my gtx 770?
However I plan on buying a corsair 350d in the future so I would also like space for my radiators in that.
Thanks.
Thanks.
