Trouble installing Linux Ultimate Edition 3.4
14 Oct 2007
Evening all, I am trying to install Linux Ultimate Edition 3.4 as a dual boot alongside my Windows Vista, but having an issue.
When I insert the CD, it says to try or install, so select install and get the following:
- Erase Ubuntu 12.04 LTS and reinstall
- Erase everything and re-install (this will erase my Vista though)
- Something else
Originally the 1st option was to install alongside Vista, which I did, so it is installed somewhere but doesn't give me the option to select it when I turn my PC on, just goes straight in to Windows (??).
If I select 'Something Else' I get the following:
Device: /dev/sda1 which is ntfs format, size 487847 MB with 134198 MB free
Device: /dev/sda2 which is ntfs format, size 11574 MB with 10648 MB free
Device: /dev/sdf1 which is ntfs format, size 286634 MB with 112416 MB free
Device: /dev/sdf6 which is ext4 format, size 204773 MB with 12476 MB free
Device: /dev/sdf5 which is swap format, size 8697 MB with 0 MB free
What ever I select I get:
'No root file system is defined. Please correct this from the partitioning menu.'
I have 2 500GB HDDs, 1 has Vista loaded on it, and the other has all my music, movies, photos etc and dont want to risk losing them.
Any ideas??
Your Linux should be installed onto the ext4 partition. Try and make a small partition on the sda1 Drive for the boot grub. Thats all I can really help with for now as I'm not at my PC.
Got it working. When I turn my PC on, I select Boot Menu and choose my 2nd HDD and it then gives me the option for Linux :)
Cheers mate
