As the title says, I'm having trouble getting a good mount with my newly purchased supremacy evo.
I'm mounting to an i7 2700k on a gigabyte GA-Z68X-UD5-B3.
I've had most of the hardware for a number of years now and just added an extra radiator for silent cooling and changed from the trusty old Antec p182se case to the Fractal Define R6.
So I stripped it all down and rebuilt everything meticulously, giving everything a good cleanup and dusting.
I leak tested the water cooling and bled the system and all was good, but when it came to booting up I checked temperatures and found that the cpu was idling at about 40c with spikes to 65c. I ran Intel burn best for about 10 seconds before several of the cores hit 90c so I stopped it and shut down to investigate.
I couldn't see anything wrong so drained and stripped everything to remount the cpu block and found it had very poor contact with the cpu.
I've tried remounting a few times and seem to get almost the exact same result each time.
I can't see any warping/distortion in the cpu or waterblock so I'm really not sure what I'm doing wrong with the mounting.
Please see the attached photos.
Oh and I'm using Thermal Grizzly Kyronaut TIM.
Any help would be greatly appreciated!
